This is my first full length movie attempt.
I'm using Smartripper.
If my aim is to eventually make a VCD.
1)In the settings,if I only want basic stereo audio output do I uncheck everything else but 2 channel english?
2)Is there a way to accurately split the vob's in half?
(I found through experimenting that even if I split the vob's into reasonably equal parts,the end result after encoding is quite different...ie:unbalanced).
3)Is there any reason why I cant feed the vob's directly into TMPGE for encoding?
Thanks in advance
"Today is only yesterdays tomorrow"
Nope......
The audio track for two channel english is almost always director commentary or some such drivel. You need to decode the ac3 6 channel for your (s)vcd
Smartripper will merge vobs. If you want two of approx. the same size look at the chapter selection of smartripper and just add the chapters to be two fairly equal end running times
If you only want the video and audio w/out subs then you should even be able to do that with a FAT partition
My first attempt to backup a DVD failed...
By Inkognito in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 18:07 -
whats the real different between a 1080 Blue Ray Rip and its Original BD ?
By Benygh in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2009, 10:52 -
PC shutsdown when I attempt to burn DVD
By steve1040 in forum ComputerReplies: 2Last Post: 21st Oct 2008, 10:10 -
pc only boots on second attempt
By bassbinn in forum ComputerReplies: 6Last Post: 2nd Nov 2007, 15:37 -
Bizarre attempt to buy DvdFab
By VegasBud in forum ComputerReplies: 1Last Post: 8th Jul 2007, 20:54
