Just when I thought I had success
I converted another home video AVI to MPEG 2 DVD with TMPG. Smae HIGH setting. Now when I open DVD movie factory and want to create menu and burn, it will not open the MPEG . Says it is not a DVD mpeg file...
Is this a TMPG bug on creation or a ULEAD problem in being narrow ? HELP !
ROB
Results 1 to 9 of 9
Are you sure you used the DVD template? Proper NTSC or PAL?
Panasonic DMR-ES45VS, keep those discs a burnin' -
Yeah I did...and now I am further 'screwed'. The motion blur problem which has been fixed for several weeks is mysteriously back...UGGGGGG
My 720 by 480 AVI capture gets converted in TMPG and was great..No the interlace BLUR is back (yes, even on tv) and I DONT KNOW WHY ....NOOOOOOOOOOOOO...Took me two weeks to fix this, been working fine and SOMETHING has gotton in there and screwed the pooch... -
TMPGEnc forum. Problems already listed with Ulead DVD products & TMPGEnc.
Now I have it working perfect again.
Here is the trick(I should write a guide)
source is AVI 720 by 480 captured in virtual dub and then produced (same settings ) in Sonic Video factory. Could be any 720 by 480 avi.
Feed to TMPG
Settings for TMPG
NTSC high quality
CBR 6000
VBV 224
INTERLACE
9 bits
Video
TOP field first (for video from camcorder, non-film)
4:3 525 704 by 480
FULL
GOP
1
5
2
1
18
first two boxes checked, 3rd unchecked
Quant
First box uncheked
next two checked
audio
384
48000khrz
Result
No motion blur
ULEAD accepts file
Menu and burn no problem at all
Net picture reult on tv very high quality -
Good work Arcorob - this might help alot of people!
I am going to write a very easy , dteailed guide from AVI capture, to TMPG , to the link for ULEAD DVD MOVIE factory for final burn. Every one is picture perfect now..No sync issue, quality excellent and best of all , REPEATABLE...LOL
I'm having the same problems using the help guide for Pal settings. Where is the TEMPGEnc forum?Originally Posted by Xtasy2002
Thanks -
it is at the tmpg website
go here
http://www.tmpgenc.net/e_main.html
and click on BBS (always say cancel or no to the langauge pack)
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
WMM Cannot Recognize .mpg File
By shecec in forum EditingReplies: 4Last Post: 9th Jun 2010, 09:07 -
Newbie wanting help? Import DVD/MPEG in Ulead VideoStudio
By Mark75 in forum EditingReplies: 4Last Post: 30th Oct 2008, 16:52 -
5982 doesnt recognize correct SRT file
By chits007 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Mar 2008, 23:30 -
Ulead DVD MovieFactory 6 - Doesn't recognize DVD
By urlilgurl017 in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2007, 12:52
