i try to open a .m2v fine in the video source thing in TMPGEnc and it says something like 'File "movie.m2v" cannot open, or unsupported'. I'm almost postive i made the .m2v correctly also.
You did not mention if you did any of these steps:
If you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello.
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 03:57 -
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 15:42 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
