i have an large mpeg clip where the audio is out of sync with the vidio is there anyway this can be re aligned. Thanks
You could try Demuxing the MPG into MPV and MPA, and then editing the MPA so it will be at the same time length as the video, and then Multiplexing the two files together should get you a new and synced MPG file.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
