i dunno if this goes here, so if not, move it please.
how do i rip a vcd? is there a program i can use like ripping a dvd? i try sending the .dat file from the MPEGAV folder to my documents folder and sometimes it works, and sometimes it wont. sometimes when i extract it, this is when it doesn't work, i try to convert the dat file to mpg and i get a error midway through conversion with vcdgear. or i will rename the file from .dat to .mpg and try to re-encode with tmpegenc and it starts off with little green squares. or i will just rename it from .dat to .mpg and it wont burn. anyone know what to do?
if you want to make a copy of the vcd, you can use nero's cd cop software (cd-to-cd)
if you want to copy it to your harddrive, just use windows explorer and copy it to your hard drive. the .dat file will play in media player as is. you can rename it to .mpg without any problems. if you really want to be sure, you should use vcdgear (and it's gui) to make it into a real mpg w/o the vcd headers.
however, you should be able to burn the .dat as a vcd in nero. if not, you should use vcdgear and convert the .dat into a true .mpg and then burn it as vcd in nero (using nero's vcd template... NOT as a data disc)
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
New, have some ripping Q's
By RooD in forum Blu-ray RippingReplies: 3Last Post: 10th Dec 2010, 10:57 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Aug 2010, 23:01 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 22:40 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22
