I created a avi file with a pinicale av card with the software supplied with the card. The avi came out great. The problem is, I can't open the avi with tmepgnc. Why?
Please Help
Jim
ps. ive alrsdy suffered with ati.
Results 1 to 11 of 11
I used virtualdup as frameserver. It reads AVI from StudioAV and outputs to TMEGEnc.
I do not have my PC with me now.But it is something like as follows.
1. install virtualdup. (from the tools section of this site, you should be able to find it).
2. run virtualdup -> FILE -> open AVI (i.e., your StudioAV file).
3. FILE->frameserver->specify output file.
4. run TMEPGEnc.
5. Enter the output file in 3 as the video input in TMEPGEnc.
6. Click START to start encoding.
Have fun. -
Sorry, but Virtualdub is vaporware which will not open AVI files created with any software anyone is likely to use. FACT: Virtualdub cannot open AVI files I create with Ulead Media Studio Pro 6.0. FACT: Virtualdub cannot open AVI files created with Adobe Premiere. FACT: Virtualdub cannot open AVI files created with VEGAS video editor.
Virtual is vaporware. It won't work on any AVI files you are likely to have, and it will not capture with any video capture device you are likely to own.
If you are as disgusted by this as everyone else, permit me to suggest that you complain loudly and vociferously to the author of VirtualDub until he fixes his vaporware so that it actually works with AVI files people use in the real world. -
XED, I personally am getting sick of this shit. If you don't know how to use or don't like a program, say so. To continually bash one of the most useful programs available for this hobby, and to make false statements about it, is unacceptable.
VDUB opens every AVI type I have tried, from over 30Gig cap files, Divx 3 and 5, XVID, segmented avi, MPG1, etc. Its the only cutter I use and never gives me a synch problem. You probably have an issue with DV Codecs.
On top of that, it is free, often updated, and very popular. There are many filters available for it and it frameserves to CCE and TMPGenc without issue.
BTW, the definition of vaporware is software advertised and promoted but never released.
To the Newbies - XED probably has his VCR clock blinking 12:00 and buys lots of floppies cause he hasn't figured out how to format them yet. Ignore his advice on VDUB, check other opinions, I think you will find he is just about the only person with this attitude. Some possibly personal reasons for this have been suggested in other posts. -
I personally think that Xed has been spurned by the author of VirtualDub. Xed is sexually attracted to the author, but the author wanted nothing to do with Xed.Originally Posted by Nelson37--
Will -
Please just give me some good advice, I ll experiment with vdub.
Ya,ll need to get a divorce.
jim -
evening,
wirenut1
basically, if you are talking about about DV, then you need to first:
* D/L a DV codec and install it
* then, tmpg should be able to open it
* also, vdub should be able to open and read it as well.
If AVI file is based on a divX codec, then, ylou need to:
* D/L the codec that THAT divX file is based, ie, divX v3.11 or divX v5.0.2
* install it, and tmpg or vdub should be able to open and read it
I think that's about it.
-vhelp -
People with lesser intelligence should stay away from digital video!
"The software said Win XP or better, so I Installed Linux" -
I tried it this morning. It works like following.
1. Run Studio -> edit -> open your video file -> make movie -> AVI -> format DV
2. install virtualdup. (from the tools section of this site, you should be able to find it).
3. run virtualdup -> FILE -> open AVI (i.e., your Studio output file).
4. FILE->frameserver->specify output file -> start.
5. run TMPGEnc
6. select the output file from step 4 as video input.
7 start encoding.
At least, this works for me.
DV Capture Problem
By sailworkless in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 22nd Sep 2011, 10:14 -
capture problem
By Mario09 in forum Capturing and VCRReplies: 2Last Post: 21st Jan 2011, 07:10 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
Capture Problem
By Driftking978 in forum Capturing and VCRReplies: 5Last Post: 28th Apr 2008, 17:44 -
Capture problem
By jjaha in forum Capturing and VCRReplies: 0Last Post: 9th Mar 2008, 15:08
