I'm trying to encode a DivX file to MPEG, but Cinema Craft Encoder tells me the file type is unsupported (div3). Premiere gives me a similar message if I try to load the file. This file will play fine, however, in windows media player. It's been suggested that I simply frameserve the file, but I'd like an actual fix to the problem instead of trying to work around it. I've tried uninstalling and reinstalling everything. Nothing works.
Thanks for any help!
Are you using the genuine DivX 3 codecs ? or just getting number 4 or 5 to handle them?
Try installing DivX 3 and see how that goes, personally I have number 3 and 4 installed independantly on My system, and 5 gets installed and then uninstalled when Im finished with it. It cause serious problems for My system.
good luck
TLTwThe Hellsing family will purify this world... -
Ok, I played around with it a little more, uninstalling and installing, and got it to work in CCE, but not in Premiere... weird. but thanks.
frame edit any format in premiere
By krohm in forum EditingReplies: 41Last Post: 14th Jan 2011, 18:21 -
Possible to encode a Premiere Pro video in DivX format? (total noob seeks advice)
By metathran in forum EditingReplies: 24Last Post: 30th Jan 2010, 21:55 -
File Format Not recognized - Using MagicISo/gBurner
By Teac23 in forum ComputerReplies: 4Last Post: 24th Jun 2009, 07:44 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 17:51 -
Premiere - how do I change capture format?
By djbryson in forum Capturing and VCRReplies: 15Last Post: 17th Nov 2007, 10:42
