When I'm editing the avi file I want to convert to MPG thru TMPGEnc, no audio is present but when I open and play the .avi file, the sounds there..what happened?![]()
Results 1 to 11 of 11
did you try stipping the sound out with Vdub?Originally Posted by enferno
I have virtualdub, don't know how to do that though and don't know how to burn it as two files.
drag the AVI file into VirtualDubOriginally Posted by enferno
Go to Audio -> WAV Audio
this should pop up a box asking you for a file name
just type in whatever.wav (not actually whatever, not that it matters)
Then you should have the WAV file. then drop the avi into TMPGenc, and hit the browse button next to audio source, and select the WAV file you created, then encode -
Increasing DirectShow Multimedia File Reader filter's priority to 4-5 (TMPGEnc->Option->Environmental setting...->VFAPI plug-in) helps when audio is rendered through DirectShow filters. Make sure that Audio Source: box contains the path to your AVI or WAV.
woohoo! it worked! thanks 0 kewl and johneboy
wait..
I had to burn 2 different VCDs because the file was too big to fit into a regular CD-R. I did the same thing with the second part that I did with the first, but the audio isn't in sync with the video. Actually, I'm not even sure if the audio that's playing is for this part of the video. Um..please help!
PLEASE! I need help this now!!
I had to burn 2 different VCDs because the file was too big to fit into a regular CD-R. I did the same thing with the second part that I did with the first, but the audio isn't in sync with the video. Actually, I'm not even sure if the audio that's playing is for this part of the video. Um..please help! -
hrrmmmOriginally Posted by enferno
best thing i can tell ya, is to demux the second MPG file.. the one thats outta sync.. And drop the audio file into a audio editor (such as goldwave) then push play on the movie, and the audio and determine how many seconds outta sync it is.. then either add or cut out the silence
Audio out of sync after conversion
By user2008 in forum DVD RippingReplies: 5Last Post: 13th Nov 2010, 05:13 -
no audio after conversion?
By bviruet in forum ffmpegX general discussionReplies: 1Last Post: 15th Apr 2008, 01:25 -
No Audio after conversion
By gcam in forum Video ConversionReplies: 6Last Post: 19th Feb 2008, 13:53 -
.ts conversion - no audio
By saintloup in forum ffmpegX general discussionReplies: 1Last Post: 14th Feb 2008, 16:27 -
AC3 audio conversion
By exekutive in forum ffmpegX general discussionReplies: 9Last Post: 11th Nov 2007, 14:12
