ok i make a dvd complient mpg2 file with tmpg, using there ntsc template, mpeg1 layer II audio
when its fooshed converting and i check the file it plays back fine..
heres the problem, i start up ulead dvd movie factory, start a new dvd project etc etc,
when i create my video_ts foldes and i check the fiels with power dvd the movie is all jerky and sound is terribly out of sync.
the file that tpmg creates is perfect so it must be something thats wrong in ulead,, any help please?
Results 1 to 13 of 13
There are a lot of ppl reporting problems with TMPGEnc encoded files and Ulead DVD products. Check out the TMPGEnc forum for more.
got a link? hmm so its tmpg? i dont quit understand becasue the actuall finished file that tmpg creates is fine when played back, only problem is when i nock it threw ulead.
If you're using a high bit rate in TMPGEnc, I suggest lowering it a little bit.
the file that tmpg creates is fine, so ur telling me ulead can only take uptoa certain bitrate?
I captured, edited and encodec a MPEG2 SVCD Compliant using Pinnacle Studio 8, than i made the authorind with this Ulead DVD Moviefactory and, when i tested the CD in my DVD Player, the audio of ******* out of sync too...
I'll try Ulead DVD Workshop now. -
First off you should'nt curse like that,
Now from what I've read on this site if you are letting ulead re-encode you video it will screw it up. read the forums for the way to stop ulead from re-encoding, I had this problem with vs6, now I don't.
i wasnt cursing,, sorry if it seemed liek i did.
ok, when i make my cideo_ts folders,, uldea multiplexs the files then makes the video_ts folders , when i test with power dvd the file is all jerky.
how do i stop ulead from converting my files? -
ok i the av i i converted from was 23.9 fps, so i check the film / movie option on tmpg when xonverting, for some reason if i encde this avi file anythng over 4000 kbits when ulead movie fatory makes the video_ts fodler and files, the movie is really skrewed, jerking and audio out of sync.
when encoded at 4000 its fine, very strange as ive encoded some movies at 80000 and theyhave been fine.
any1 else had anything simluar? -
Gecko, did'nt mean you, was refering to Ticiano. as for the rest of it I'm new to all this I was thinking that the file Tmpegec, makes is ready to burn if compliant with dvd standard. Figured all you had to do was open ulead import file then export to dvd writer plugin I may be wrong, sorry if I've given you wrong info.
Try these TMPGenc settings used by someone in another thread for DVD quality MPEG that Ulead likes:
source is AVI 720 by 480. Could be any 720 by 480 avi.
Feed to TMPG
Settings for TMPG
NTSC high quality
CBR 6000
VBV 224
INTERLACE
9 bits
Video
TOP field first (for video from camcorder, non-film)
4:3 525 704 by 480
FULL
GOP
1
5
2
1
18
first two boxes checked, 3rd unchecked
Quant
First box uncheked
next two checked
audio
384
48000khrz
Result
No motion blur
ULEAD accepts file
Menu and burn no problem at all
Net picture reult on tv very high qualityPanasonic DMR-ES45VS, keep those discs a burnin' -
tryed that, cant test the ifo file with pwoer dvd , causes a crash, cant be bothered to burn it to dvdr and waste £1 lol.
i think its just this 1 movie, others have been fine,, ill have to do it at 4000kbits bitrate
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 20:42 -
I have a problem using Ulead DVD Movie factory including.AVI Files, the pro
By OggO1984 in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2009, 08:42 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
