  1. What should I use for a 20.000FPS movie, NTSC, NTSC Film, or PAl??
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    well the easy solution is to encode it at 24fps and apply pulldown to it ..
    will play a little fast and you will have to possabily resync audio -- unless you do audio and vid togther and it holds up ..
    this of course assumes its a progressive movie ..
    myself i would re-render it in a video compositor program ... but not a do it yourself at home job ..
    maybe someone knows a easy/another way ...
