How do you get rid of them?
You can use TMPGenc to do that, using : Files -->MPEG tools -->Cut & merge you add the mpeg file, select it and click edit. use the bracket to select the portion you whant to keep!
Hope it help!
you dont like them? good to know ur stealing someone
else's work dont it?
i just rip w/o the menus and never see those anyway -
Read this guide:http://www.doom9.org//mpg/ifoedit-advanced.htmHope this helps!
Anonymous member taken down by FBI
By ranchhand in forum Off topicReplies: 2Last Post: 17th Apr 2012, 20:07 -
help the FBI solve a murder
By deadrats in forum Off topicReplies: 3Last Post: 10th Apr 2011, 00:38 -
Test warnings
By alfresco in forum TestReplies: 3Last Post: 1st Feb 2010, 05:35 -
FBI may be getting in touch soon... hiphip hooray!:]
By ahhaa in forum ComputerReplies: 0Last Post: 14th Jun 2007, 10:03 -
Laser printer warnings?
By Bartron in forum ComputerReplies: 8Last Post: 8th May 2007, 12:07
