Can anyone help me plz I recently downloaded A film and it came down ok but when I Tried To Convert it to mpeg using tmpgenc the picture goes purple in places.
Can any1 tell me whats causing this or how do I get rid of it i have the nimo codec pack installed on my computer and im using windows xp home edition and the tmpgenc im using is version 2.57.....
So can anyone help me....
Is there anything i need to install into it to run on xp or what?
Thanx
Problems:
Some common TMPGEnc problems:
If you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
If TMPGEnc freezes or crashes when converting or you receive errors such as
Unexpected decimal point calculation
Illegal floating decimal point calculation order
Try first to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
Or try to convert the audio to wav before converting(If you have problems extracting the audio using Virtualdub try use Goldwave or AVI2WAV).
Or try to repair the AVI,DivX or the ASF.
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 12:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
