What's the best card for PC - Windows XP? I'm looking to capture from a mini dv camera straight to computer via firewire with Adobe Premiere or something like that. Any suggestions?
Jeff
Results 1 to 9 of 9
A firewire card does not capture, it simply transfers DV video, so to be honest a firwire card is a firewire card, paying lots more money wont get any better quality. You can buy them for about £20
well, yeah, i know, but you can just transfer video straight from mini dv camera to firewire card to video on computer right? good to know that it doesn't really matter brand-wise
jeff -
Adding a firewire card is like adding a card to add ethernet or usb ports. If it's not cheap you were ripped off
. The companies that sell $100 firewire cards are selling you the software. I paid $20 for mine and it works just fine (it was to replace the $15 one I bought 2 years ago... when it started acting funny I decided it was cheaper to buy a new one than troubleshoot). Even the $20 one came with software to capture the DV (it's free anyway if you use DVIO and such)
I recommend Studio DV 8. It includes Studio DV8 software and a firewire card. About $80-90 and $30 rebate available. Studio DV is a very good video editing program.
the ads pyro is the one recomended by avid and others ... works fine for me also .. just the cheapest version of it is all you need ..
I didn't see you got Premiere. In that case, you better get the cheapest one as BJ said.
If you want the card bundled with a great software: $79
Pinnacle Studio 8 DV Professional Movie Making System
http://www.compusa.com/products/product_info.asp?product_code=295250
Just the card for $29
http://www.compusa.com/products/product_info.asp?product_code=280901
WindowsXP's Free MovieMaker is good enough for most people. -
fateman,
yeah, as bj_m said, the (ads pyro) is as good a card as any, and with
some software (doesn't work on my win98 though, needs 98SE, as most
software do these days, so be aware of this issue when you're looking
for, DV endeavors)
* Got my ads pyro card (among 3 other cards/software packs) for $39 at
CC.
* Got SIIG card for $49
* and 2 other cards for $20 something.
I use either DVIO or mostly I use my favorite "RSDVCAP.EXE"...
Mind you, i don't really use them anymore, but when I do use them, I
use the "RSDVCAP.EXE" app. Has Type 1 and Type 2 avi file types.
Also, make sure that you select for Type 2, cause this will be the most
universal (or accepted into any app) w/out issues, where Type 1 will not
or give you hickups due to Audio interleaving. In short, Just use Type 2.
That's it!!
-vhelp
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 18:22 -
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
DV Camera to DVD plus Firewire Card Help.
By Sikander in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2007, 15:35 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
