Hello,
Source material camcorder captured with Virtualdub 720 by 480
Use Sonic Video Factory to make transiitions, music, etc. .. and again out to 720 by 480. Now this is HEAVY interlace material and unless I use TMPG I would get motion blur.
Anyway, uses TMPG at the setting s given on this set as the HIGH QUALITY SETTINGS etc.. http://pwp.netcabo.pt/0165394101/TMPGEnc_Template.html
Lastly, I use BAldricks process (IFOEDIT and NERO)
Result is beatiful picture but inconsistant on machines. On apex 500w , great all around. On Pioneer DV414 get choppy sound. On GE 100EN get slightly out of sync sound, all the same disk.
I figure my rates were too high perhaps ?
I tried NEODVD 3.0 using the AVI to DVD and it came out compatible but WICKED motion blur.
Okay, last test.
USED TMPG to get the desired PICTURE because it is the ONLY thing that eliminates motion blur. Then fed the DVD MPEG to NEODVD. Worked and seems to play in all three machines. (I have to check the sync of lips yet)
SO my question (SOrry it took so long to get here)
If I use NEODVD as the final step, is it RENCODING my already perfectly coded MPEG2 to a lesser quality before I burn ?
Is there a better way ? I would REALLY like to use the TMPG to IFOEDIT to NERO routine, but NERO seems to be fouling the final up ...Like I say, It plays in one machine but the other 2 SAY they can handle DVD+R DVD+RW yet they don't do it so wll.
APEX 500W doesn't count because it ould play a pizza if you put one in..LOL
PLEASE help. I need a stable process as these are for WEDDING video's...Thanks....
what is HEAVY interlace ? if your looking on a pc monitor - its different than on a TV ....
if you try to remove the interlace so it looks good on your pc it will often look blurred on a tv ..
anyway set your max bit rate to 7000 as you find this a lot more compatable .. -
Thank you and I answered another question for myself...NEODVD DOES LOSE RESOLUTION !
i checked the IFO file created after NERO
I checked the IFO file after NEODVD
NERO says MPEG 2 compression
NEODVD says MPEG 1 !!!! Uggggg
SO I am STill stuck
nero just doesn''t make the compatibility...NOW WHAT !!! -
i thought you were using tmpgenc -- whats all that other stuff encoding for
How can I batch process AVI files and overwrite the originals? Please help!
By DrivesALot in forum Video ConversionReplies: 5Last Post: 21st Oct 2011, 20:59 -
DVD/vob/mpeg to Avi/xvid automated process, Help!
By sinz in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 01:08 -
What is a good xvid, avi cutter (for unwanted commercials) w/batch process?
By kbal in forum Video ConversionReplies: 5Last Post: 20th Dec 2007, 10:34 -
AVI to DVD process
By Vipero00 in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2007, 01:44 -
AVI Converting Process
By nkneedeep in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 20th Jun 2007, 15:27
