  1. ok here is my problem i have a film that has 2 angles in the main movie but i cant remove the angle using ifoedit as the angles box is grayed out does anyone know of another way to remove the angles ??
    this what i have done so far
    dvd decripter in file mode as i want to keep all the menu's and extra's
    ifoedit to remove unwanted audio and subtitles
    Number of Title Play Maps: 38 (vmg_ptt_srpt)
    Title 1: VTS_1, TTN_1 (Angles: 2) (Chapters: 28 ) (Start Sector 20264)
    Title 2: VTS_2, TTN_1 (Angles: 1) (Chapters: 1) (Start Sector 1502789)
    Title 3: VTS_3, TTN_1 (Angles: 1) (Chapters: 1) (Start Sector 1502969)
    and so on
  2. Did you try SmartRipper to remove the angle?
  3. were is the option in smart ripper in back up mode to remove the angle as i cant find it as i am keeping every extra from the disk
  4. can anyone help me with this ???????????
  5. ok i have now tried
    IfoEdit ver 0.9.0.0
    IfoEdit ver 0.9.1.0
    IfoEdit ver 0.6.0.0
    IfoEdit ver 0.9.5.0
    IfoEdit ver 0.8.2.0
    and i can't remove the unwanted angle with any off those as the
    remove angle box is still grayed out ??????
    Nov 2001
    Sweet Home Alabama USA
    To rip VOBs and remove other angles, I use DVDDecrypter. Mode/File and Tools/Settings/File mode/Multi Angle Processing/Retain Angle "".
