I actually have the divx converted to mpg w/ audio using TMPGEnc and the file works fine. However, I need to extract the video only, because I want to keep the ac3 and my dvd authoring program will not accept mpg video with audio (using dvdmaestro). Disc 1 converted to mpg and then to m2v without any problems. BUT, I can not extract just the video from the file using TMPGEnc. When I use mpeg tools and demultiplex or simple demultiplex, it will convert about 200+ megs of the video and stop. I've tried a couple of other programs with the same result. Anyone have a suggestion?
Thanks.
Scotsman
Results 1 to 1 of 1
.m2v + .ac3 + .sub/.sub to .mpg
By stevie99 in forum Video ConversionReplies: 2Last Post: 9th Apr 2012, 03:01 -
HD .m2v and .AC3 Help Needed Please
By lovelylisa in forum Video ConversionReplies: 40Last Post: 29th Jun 2011, 08:20 -
How Do I Join M2V and AC3 Files?
By lovelylisa in forum Video ConversionReplies: 1Last Post: 6th Jun 2011, 17:13 -
m2v + ac3 problem?
By just in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2008, 17:24 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
