As I’m rather new to this I’m looking for a little advice on how to proceed.
I’ve just downloaded a film ,in two parts from Kazaa, the format of both is Mpeg,
part 1 consists of 723Mb (758,418,808 bytes
part 2 consists of 715Mb (750,370,816 bytes
Obviously first off I’d like to know if the Mpeg format be suitable to view on a DVD player (not a PC DVD but one which is compatible to CDR’s) if I copied it as it is onto a CDR !
The second part of my question is what is considered a good program to convert the above for copying onto a viewable CDR, does it need compressing to do it and if so to what format.
Any help gratefully appreciated.
Regards
Syke
Compatibility with CD-R's does not mean you can just drop a MPEG down to a CDR and expect it to run in a standalone DVD player. It still needs to be converted into VCD or SVCD structure (proper bitrates, filenames, directory names, etc.) I suspect the MPEG's you downoaded are probably already recorded at the proper bitrate, in MPEG-1 format for VCD. If that is the case. I suggest you get VCDEasy(you can find it in the tools section) install it (you may have to install the ForceASPI drivers to get it to run) and then burn the files to CDR using VCD format. Once VCDEasy is installed it is very easy to use. You should be able to find a number of guides on using VCDEasy on this website.
Thanks very much for that hwoodwar, I will try to find & drop VCDEasy now and give it a try.
Will let you know how I get on.
Thanks again
Syke -
I have often just burned mpg files on a CD-r and played it in my DVD Player. I just select the folder and press Play. The only thing is it doesn't show you the elapsed time done that way.
I usually use Nero, though. You can get it from Kazaa lite. Very easy to use.
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 10:33 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 17:31 -
Creating Clips effectively from large mpegs -- HDD Cameras
By bryan andrews in forum EditingReplies: 1Last Post: 22nd Jan 2009, 11:36 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 12:10 -
TubeStick and splitting large mpegs
By benblack in forum MacReplies: 7Last Post: 30th Sep 2007, 15:11
