I recently began to learn how to rip and encode dvd’s into vcd’s from obtaining knowledge from http://www.vcdhelp.com, and Sefy’s assistance. Today I finished up my first rip and encode on a dvd called “No Escape”. I burned it on 2 cd-r’s with Nero 5.5, and it seems to work pretty decent. However, I’m sure I need to learn more about which templates to use and a better understanding on aspect ratio.
I used this method: Smart Ripper, DVD2AVI and convert to VCD/XVCD (or variants) with TMPGEnc. For the template I used: SxVCD for NTSC Enhanced.MCF, and I left all the default values. The movie was a 2 hour movie and it encoded at approx- 550mb per cd (slit up per cd)
My question is I’m planning to rip and encode another dvd soon, with a aspect ratio of 2.35:1 Am I suppose to factor the aspect ratio into the templates values for a better encode? If so, how?
Can someone recommend a excellent template to use and can I manipulate the bit rate from 1150kbps, to approx 1500kbps? If I up the bit rate, will the quality turn out better?
SB at: valley_view_ca@yahoo.com
Results 1 to 1 of 1
16:9 Aspect ratio
By jeffh123 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Aug 2011, 19:44 -
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 13:30 -
Aspect ratio
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Mar 2010, 11:25 -
16:10 Aspect Ratio
By SWBisbee in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2008, 01:41 -
Aspect Ratio's
By AndySpring in forum Newbie / General discussionsReplies: 7Last Post: 23rd May 2007, 12:55
