Hello I have a lot of footage I want to edit and I am going to use Adobe Premiere 6.5. With the installation, I did not install the Quicktime plugins and am regreting it. I now wish to install it and I also have the Panasonic MPEG1 Encoder I also wish to add as a plug-in, but am not sure how to add them. I cant use the CD to copy the files so please dont ask me to. Im sure its been explained on this site, but I can never find anything
Sorry!!
Ok forget the question above, new idea. Using my DV camera, my Dazzle capture card (not the USB thing) and Premiere 6.5, I want to capture the footage directly to DivX in a good quality. What pass do I want, what config for all the settings, I got the latest DivX codec in Adobe. I also wonder if it is possible to capture the sound to MP3 in Premiere? T H A N K Y O U ! !
mm ... take 1 compressed digital format and send it out analog instead and convert it back to digital and compress it to another really compressed format on the fly - then edit it ? then compress it again to Mpeg1 for vcd ?
how about get a firewire card and transfer your DV material as DV - edit it as DV , and encode it as MPEG1 with the built in mpeg1/2 encoder in Premiere 6.5 ?
you would have much better end product .. -
I have a card which is built-in to the machine, its got 2 ports which are kinda square with a pointed bit one end.
________
|________/ Sorta like that... It plugs into the DV socket of the camera.
DV socket looks like...
__ __
|_____|
Basically it is capturing at 1MB/2 seconds no matter what codec etc I use. I am doing it right.. I think, what other good carpture software is there? What sort of card have I got, its by Dazzle - Thought it was firewire?!
I used Premieres MPEG encoder and brought 270MB (1min 16sec) clip to 16.8MB. But I dnt have enuff hard drive for whole tape (2hrs) It would take like 50GB at the rate it captures...
lol pictures came out wrong...
________
|________/
__ __
|_____|
Ignore the "." s
Is there a Premiere plug in for focus and exposure issues?
By kissvid in forum EditingReplies: 5Last Post: 11th Aug 2011, 16:09 -
Any psychedelic or kaleidoscope effects plug-ins or software?
By johnharlin in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2011, 09:57 -
Descriptions for Audio Effect Plug-ins-- Vegas 6.0d
By solarblast in forum AudioReplies: 4Last Post: 15th Nov 2008, 23:39 -
Anyone know good Video Editing tools? Sharpeners, plug-ins, grain, etc?
By HOTPROPHET in forum Newbie / General discussionsReplies: 4Last Post: 21st May 2008, 14:04 -
I'm wanting to cut some scenes and add some fade-ins to a DVD video.
By Ryan J in forum MacReplies: 4Last Post: 17th Apr 2008, 09:42
