Ok i finally found out what's happening.
When i enter a folder that contains a mpeg2 movie (doesn't matter what size), the folder crashes.
I'm not using preview mode, i'm using list or details mode.
Does anyone know how i can solve this problem ?
I'm using WinXP.
"Against All Odds"
when i try to watch a mpeg2 movie my computer crashes as well.
i'm using XP too.
anyone know the cause and how to solve this? -
are you using windows media version 9 or lower it isnot the greatest try power dvd to avoid freezing or crashing
Nobody knows anything for the folder crash ?
(can't use windvd for that lol)
"Against All Odds" -
This happens to me too (for both MPEG 1 & 2) when I select the file - when Windows try to create that preview window in the left margin. The solution is to never select the offending MPEG with the mouse. I use a DOS window to manipulate these files, and WinDVD to view them.
I think this is a problem that is caused by Nimo codec pack, that has replaced some codecs with versions that Windows doesn't like... If anyone has a cure for this, I'd be happy to listen!
/Mats -
Try not to use media player to view vobs or mpeg2,cause it rarely
will read it, and if ur not careful ur system might lock up,happened
a few times,stay away from media player 9,its stilll in beta mode,
if u get it,make sure sys restore will work,dont get movie maker2
from microsoft either,it dont work,it just blue screens you in XP -
Yes, might very well be WMP9 too. I can live without WMP until MS finds it to release the real thing. If the latest effort (Release candidate!) is anything to go by, it's gonna be some time - I can't find any improvements since the beta when it comes to what formats it handles...
/Mats
TMPGENC Xpress and Video Mastering Works both crash at 99% of .mkv to mpeg2
By i am x in forum Video ConversionReplies: 3Last Post: 15th Jul 2014, 09:40 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09 -
Vegas Movie Studio 10 crash
By magillagorilla in forum EditingReplies: 46Last Post: 29th Aug 2011, 02:35 -
Video TS folder convert to MPEG2??
By famreeks in forum Newbie / General discussionsReplies: 3Last Post: 16th Jan 2008, 22:16 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 01:38
