  1. Hi
    I have a problem burning with dru500a and nero 55917. It says: "can't finalize lead out". I've made 4 coasters right now...
    Anyone helps?
  2. Try changing media. Go with a DVD-R major brand.
  3. Did you use Memorex DVD-R? I got some problems with Memorex.
    If you want cheap and reliable media, try Ritek Prime. I burnt 15 out of 50 without any problem. I purchased from www.shop4tech.com.
  4. it's Nero problem. there were a post few days ago explaining solution:
    http://www.vcdhelp.com/forum/viewtopic.php?t=123595
  5. Thanks a lot
    Itīs right the probles was with nero 55917 .1, I downgraded and it works fine...
