I am a newbie to burn VCD and I want to ask how to burn the BMWfilm to VCD with the best quality. Please tell me.
Firstly, you need to provide more details.
Some tips:
- use a good MPEG-1 encoder like TMPGEnc (which also happens to be freeware for MPEG-1 encoding)
- if you are capturing the video, capturing the full vertical resolution / both fields per frame (i.e., x480 or x576 for NTSC and PAL respectively) will yield better results
- try to have as clean a source as possible.
- if it is B/W, you may want to run your captured video through VirtualDub with the grayscale filter to completely remove all the colour out --> this will save you some bits when encoding --> better quality.
Regards.Michael Tam
w: Morsels of Evidence -
look at these guides here
http://www.vcdhelp.com/forum/viewtopic.php?t=124856
Movie quality is bad after burn to DVD
By ngochan in forum Video ConversionReplies: 4Last Post: 25th Jan 2011, 23:34 -
Getting a better quality burn
By brado09 in forum DVD RippingReplies: 6Last Post: 24th Apr 2009, 10:59 -
Check quality of burn
By amerifax in forum DVD RippingReplies: 8Last Post: 18th Mar 2009, 20:34 -
Burn and quality of a HDMI movie?
By macamba in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2008, 02:54 -
Quality reduction on Burn
By barkingcat in forum Authoring (DVD)Replies: 20Last Post: 24th Mar 2008, 07:58
