  1. Hello all,
    DVD2SVCD is a killer tool, but I would like it to do one thing, and I can't seem to find a configuration option anywhere to do this: I want it to JUST make me the SVCD or VCD mpeg file and stop without continuing to make the cd images. It just takes longer and I never use them since I make my own menus.
    Little help?
    PA, USA
    Originally Posted by snarfo
    Stupid (maybe) DVD2SVCD question
    very stupid!
    lol... just kidding
    sorry, too much coffee
    anyway.. its on the finalize tab i believe.. at the bottom
    it will say something to the effect of "do not create image" or something
  3. Thanks for the speedy (if useless) reply. I'm using DVD2SVCD 1.1.0 build 1a, and the only things on my Finalize tab are 'use cdmage' and 'run this'.
    Try again?
    PA, USA
    oops.. do you have a CD IMAGE tab?
    many appologies.. not at my home computer now, so trying to go off memory, as i too turned off that option
  5. Aha! It's on the CD Image tab at the bottom.
    Silly me. Apparently I haven't had ENOUGH caffeine...
