I converted a 122min movie to SVCD, but the result turned out to be some computer grafic that looks like a plug-in for WinAmp instead. The file only got 1.3gb from a 122min movie, would thought it would be bigger. I used the standard template for "SVCD NTSC" in TMPGenc to convert.
When I convert the same movie as VCD, it works just fine.
Any settings I have to change? The result is the same with other divx movies too.
Since I did this at 6am this morning, I forgot to check if the sound was working properly. Sorry!!
Thanks.....
Are you sure you used the correct format for you TV/DVD player (ie. PAL vs. NTSC). Also you say that VCDs work fine, so are you sure you DVD player can play SVCDs?
I would encode a 1min MPEG for VCD and SVCD, make sure both play in media player, then make images of the MPEGS, burn them and test them out. -
Ok, I forgot to mention that this is in Windows I can't get the picture. I didn't try to put it on CD to test it in my DVD player. I have a Pioneer player, it can play anything you give it.
Can WMP play mpeg-2 files?
Thanks.....
why does 3D movie shows up in split screen on my 3D TV
By greenmetal in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2011, 04:08 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 01:13 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 10:10 -
Correct Terminology for a menu frame that shows a clip from the movie
By gayclarke in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2007, 08:19 -
Baffled!! Titlewriter shows nothing but DVD Player shows Movie Name
By Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 12:02
