I am having some trouble burning an SVCD, or XSVCD. I am using Nero Express 5.5.9, which keeps saying that it isn't properly encoded. I first encoded to MPEG2 720x480 4:3 29.97fps....Auto VBR 2900K max....I did change the audio rate to 128k to save some space ( I have a not-so-great audio setup).....I then cut the resulting MPEG2 file into 3........
Easy way to tell Nero "To Hell with checking just burn the darn thing....?"
Any thoughts?
Matt
Hi Matt, I am new at this but I believe SVCD format is 480 x 480. This is why Nero is asking to re-encode. If you don't own the encoder for Nero download TMPGEnc and this will convert the file for you. I hope I helped.
Same thing happened to me last night but I think the reason might be I haven't purchased the mpeg-2 plug-in from Nero. instead in using dvd2svcd to encode to mpeg-2 the burning in nero direct without express passing me over
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 11:07 -
Trouble W/ Video Filters Final Cut Express
By augiecrazy8 in forum MacReplies: 1Last Post: 2nd Sep 2008, 09:22 -
Nero burning trouble with logs.
By bufalo in forum Authoring (DVD)Replies: 4Last Post: 13th Jan 2008, 07:43 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2007, 23:54
