  1. ive just bought a Win Tv Pvr pci. it has various settings for vcd and svcd. the problem im haveing is i set it to the best or second best quaility which is MPEG2 12.0MB/sec & MPEG2 8.0MB/sec and a 30 minute t.v show save a mpeg 2 of 1.8 gig and higher . is there anyway i can convert this huge mpeg2 file to say a avi file or something so i can archive these shows ? if this is in the wrong section please let me know and ill move it ... thanks in advance
    WESTY
    sheesh
  2. not sure, but friends have capture cards and they say
    when u capture,they say it takes up huge amount of
    drive space,so u should burn it off to disc quickly or
    you cant capture very much more,try pinnacle or
    ulead dvd workshop or something else i guess
    MO, US
    1.8GB sounds about right for 30 minutes at 8Mbit/s. If you want it smaller use a lower bitrate, or convert your MPEG to DivX or a lower-bitrate MPEG file after capture.
  4. you want a conversion prog like TMPGENC which converts to a compressed much smaller MPG SVCD file ready for burning. very easy to do. www.tmpgenc.com. I got a prog called T-Rex which came with my pinnacle PCTV card and its a very good conversion prog. wish i could say the same for the card itself...
