Hi
I have alot of VCD's and I'm trying to fit as many as possible on to 1 DVD
I've copyied the DAT file from the VCD and renamed it to MPG and then I used TMPG Encode to De-Mulitplex the MPG to a M2A and a M2V
I then used IFO edit to author a new DVD which it done
Now I'm stuck
IFO Edit has made VOB's and IFO's and they play in PowerDVD but how do I go about adding another VCD to this DVD. Is there a setting in the VIDEO_TS.IFO file that I can change to tell it that there are more VOB's
Thanks in advance
Stu
Results 1 to 1 of 1
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 15:50 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 18:44 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52
