Im using TMPGENC and i have a movie, its an Avi File, I split the the AVI into a Wav file and made the first half SVCD. Now i need to know how many Millaseconds i need to gap? How can i found out how many minutes of audio to skip? Plz Help Thanks.
If the original AVI sound is in sync......then you use TMPGE to encode with the extracted WAV used as Audio Source and then you can use the Setting> Advanced>Source Range and batch encode to split the movie during the encode process .
"Today is only yesterdays tomorrow" -
Nope that didnt work, okay the movie is half baked, I got the first CD on SVCD its 41:35 minutes, i wanna get the sound to be synced for the second cd, how do i do this? Plz reply thx.
If you use the full AVI and the full WAV and load it into TMPGE.
Then using Source Range to encode the second half.
How do you know if the sound is going to be out of sync in part 2 ...if you have'nt encoded it yet???"Today is only yesterdays tomorrow"
I need to correct audio drift
By Djard in forum AudioReplies: 13Last Post: 30th Jan 2012, 17:32 -
Automatically reducing the gap between subtitles
By Niggylefrançais in forum SubtitleReplies: 2Last Post: 10th Jul 2011, 09:48 -
GIMP GAP Green Frames
By mixt in forum Newbie / General discussionsReplies: 9Last Post: 25th Apr 2011, 08:45 -
Best way to correct this avi's audio
By striker9 in forum EditingReplies: 3Last Post: 4th Nov 2010, 11:42 -
VHS to DV - Audio not correct
By jlorelle in forum Newbie / General discussionsReplies: 13Last Post: 15th Sep 2008, 10:36
