I am trying to convert avi versions of the original Star Trek to SVCD, but on a few of the episodes TMPGEnc shows that the video is like 190 min 35 sec, and 400% of disk capacity. When I play the files in Windows Media Player they're fine. Any help would be much appreciated.
I don't know if this will help you or not. I never seem to see anyone mention it. I find that when I try to encode with TMPGEnc, it often shows that the resulting file will be huge. Way bigger then what it needs to be.
So what I do is first extract the audio with Virtualdub in an uncompressed .wav format. Then I encode again with TMPGEnc, except this time I use the new .wav as the audio source. For some reason using this method makes TMPGEnc create a smaller file (the size it should be). You can give this method a try. It always works for me, or it could just be my computer. Can anyone verify that it does this on there computer too, and if so, then why?
Hope this helps.
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 02:55 -
DVD showing 60 GB size
By brucexx in forum DVD RippingReplies: 7Last Post: 30th Mar 2010, 16:22 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 05:14 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 20:48 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 15:30
