Hello all.
After an increasing pile of CD coasters, thanks to my link with a PC and an old instruction on how to create SVCDs on a Mac using TMPGEnc on the PC (or virtual)... I discovered that
having installed Toast 5.2
Final Cut Pro 3.something (can't check right now)
the export option to Toast VCD (can it BE easier?) is
a) only available when you do batch export (why is that?, is that just my Mac being funny?)
b) once you choose export to Toast VCD, there are no options to get to... options! And this is where the real problem lies: the exported MPEG1s... are NTSC however hard I tell FCP that I am a PAL user.
Can anyone help me especially with b) but a) is also welcome of course!
Take care and thanks!
No it's the same for me as wellOriginally Posted by Ender11
It doesn't seem as you can change the setting for this. It would seem as if you have to export to quicktime then export to VCD using Quicktime Pro or the Toast application itself. This would allow you to select PAL format on your video.Originally Posted by Ender11
Export from Final Cut Pro to format editable on PC (eg. AVI) retaining HD
By adrien23 in forum MacReplies: 3Last Post: 31st Mar 2011, 19:45 -
From Vegas to Final Cut Pro - How to export without (much) quality loss
By BovineofWar in forum MacReplies: 18Last Post: 28th Apr 2010, 21:04 -
Final Cut Pro Slow Export
By gooberguy in forum EditingReplies: 1Last Post: 5th Apr 2010, 16:23 -
Final Cut Pro - Export to Windows Media (WMV) Problem
By accumulator in forum MacReplies: 4Last Post: 24th Jan 2009, 22:24 -
Using Canopus ADVC110 to Export to VHS from Final Cut Pro
By richisgame in forum MacReplies: 4Last Post: 14th Sep 2007, 19:18
