Results 1 to 10 of 10
  1. Does anyone know of a DIVX-> VCD encoder that will chop off black borders?
    The black borders in my divx are actually encoded into it and part of the original film
    dvd2svcd won't do it.
    Feb 2002
    London
    umm TMPGEnc perhaps...?
    There's a feature within Setting > Advanced (tab) > Clip Frame which appears to allow this. Never done it myself but it looks promising.
    I suspect there MAY be some advice about using blocks of 16 as well, for reasons which I can't remember, however my amateur advice is a good start!
  3. ok, i found it, but it was a pain in the arse. can it not be incorparated into dvd2svcd (since it uses tmpgenc and would just need to send a few more arguments to the exe/project file?)
  4. There is a way to do it in DVD2SVCD using the Edit as part of video encoding at the bottom left of the frameserver tab. This enables you to edit the avisynth script to add a crop filter. It's not as hard as it looks. Try here to get an idea...
    http://www.avisynth.org/
    With regard to blocks of 16. If the X and Y resolutions can be divided exactly by 16, you should get faster encoding speeds as it allows for MMX optimisations to kick in (I can't remember where I got that info from so thanks to whoever!)
    GGS.
    Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour')
  5. um, ok, that looks way complicated.
    do you reckon you could type in what i have to paste into the script (and how to do it? )?
    i want to crop:
    TOP 48
    BOTTOM 54
    LEFT 5
    RIGHT 8
    thank you sooo much if you could do this
  6. ok, just entered:
    Crop(5,48,8,54)
    is that right?
    Feb 2001
    Berlin, Germany
    #avisource()
    Crop(6,48,-8,-54)#round to even values
  8. ah, cool, negative values for the opposite sides,
    Feb 2001
    Berlin, Germany
    Yes, negative values, because the arguments of Crop are (left, top, frame-width, frame-height)
  10. ok, cheers guys, encoding street fighter 2 the manga movie now WITHOUT borders in full unzoomed 16:9
