hey. ive been having this problem and am not sure how to correct it.
i capture in uncompressed avi (for best quality picture) and then i use virtual dub to edit it b4 putting it into divx. after my capture is complete, the audio is usually out of sync. ive been able to correct this in virtual dub by playing w/ the frame rate and also "audio interleaving" in the past. but for some reason (after some time passing, loading a new system and what have you)... everything goes the same until i get to vdub... i resync the audio so it matches up w/ the video and everything IN vdub.. but after its converted and i watch it... its still way out of sync (if not worse then the original).
Why is this and what can i do to correct this? i never had this problem in the past? Does anyone know of some settings in vdub that i could try that may correct this problem?
Id greatly appreciate any help
thanks so much
jerets
ive played w/ it some more. the uncompressed avi isnt that out of sync but enough that one would want to change it. when i open it in vdub it shows it as even more out of sync and when i fix it in vdub it leaves it out of sync when i convert it out of vdub... why is virtual dub doing this? anyone know how to fix it?
thanks so much
jerets -
One solution may be to fix your capture problem. Audio should NOT be out of sync while capturing. Although you have often succeeded in working around this problem using VDub, it may not work always.
Do you get frame drops?? Try reducing the capture audio sampling rate / capture as mono instead of stereo.
If you insist on full audio quality and if you can replay your source, try capture the video only first, and then capture the audio (w/o video). Multiplex this in VDub and adjust only audio offset. -
thanks for the advice... i tried capturing in vdub and i was surprised how much better i could make the video and how insync the audio was... now i just have to figure out how to work out some minor problems im having in it :P lol. wish me luck, thanks again for the advice... now its off to the capture forums
thanks again
jerets
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
