  1. Here's a strange one.
    A couple of times I have used CCE 2.64 set on 3-pass vbr to re-encode movies to reduce their size. I have ended up with a final mpv file considerably longer than the original. This will give me something along the lines of a 3 hour video file and a 2 1/2 hour audio file, causing an obvious problem with authoring.
    This doesn't happen every time, but often enough to be a pain in the butt.
    Does anyone have any idea what might be happening here?
  2. What settings are you using for CCE? Are you using the Robshot method?
  3. 3 pass VBR, adjusted in the advanced settings to give me a final file size of app. 4 gig, which usually comes out to app. 4k/second.
    Not familiar with RObshot method--got a link?
