Can I capture at 720x480 using wintv pci(bt84using win2k? I read from previous posts that it can using generic drivers, is this true? I can only capture at 640x480 at the moment....
The BT878 chipset used in the WinTV supports capture up to 720x480 (NTSC), but the Windows 2000 drivers limit it to 640x480. With the proper drivers, it should work in 720x480.
-Cart
http://www.geocities.com/lukesvideo/index.html -
Really? Where can I find the drivers(for win2k)? My card's chipset is the bt848, not the bt878....
To be honest, I don't know which drivers will allow that resolution. Perhaps if you search for other boards based on the BT848/BT878 chipset, you could try their drivers to see if they restrict the available resolutions. You could also try Hauppauge's WDM drivers with the VFW -> WDM wrapper, but this will decrease performance, and I don't know if it will work.
Is there some reason why you need to captuyre above 640x480?
-Cart
Here you can find everything for capture :
http://www.iulab.com/index.shtm?iuvcr/about
I use iuVCR more than 5 months and for me is the best way to capture 740x576(pal-DVD),480x576(SVCDpal)with Pixelview Play TV and Win2k .....
Questions about Hauppauge 1196 WinTV HVR-1250 PCI Express Card
By Wizard23 in forum Capturing and VCRReplies: 15Last Post: 25th Feb 2011, 16:22 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 01:21 -
Pinnacle PCTV HD PCI only captures at 720x480?
By wings123 in forum Capturing and VCRReplies: 4Last Post: 16th Feb 2009, 20:16 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50 -
Anyway to capture 720x480 using the Gamebridge and still play?
By Mysteriouskk in forum Capturing and VCRReplies: 0Last Post: 19th May 2007, 14:07
