Using V Dub 1.4.10 the video is slow and out of sync with the audio. I noticed under the capture menu it only list the microsoft WDM caprure driver, I have an ATI AIW 128, why is it not listed. Also i do not have access to YUY2 format. Please help.
SYSTEM:
amd K6-2 450
MICROSOFT Win ME
344 meg ram
V Dub 1.4.10 installed
Nemo codec pack
Huffyuv
ATI MMC 7.1
You give no indication of resolution or frame rate.
with only a K6-2 450. this may be the problem.
I was using the ASUS V700 Deluxe for a long time with the same problem cropping up about 50% of the time. I found out it was my K6-2 550 that was the problem. It was not powerful enough to keep up with the Huffy encoding. Trying to capture 640x480@30fps AND encode to Huffy was just too much for the little K6-2.
I have moved to an Athlon XP2000 chip now and am able to do it.--
Will
DV Capture Problem
By sailworkless in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 22nd Sep 2011, 10:14 -
capture problem
By Mario09 in forum Capturing and VCRReplies: 2Last Post: 21st Jan 2011, 07:10 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
Capture Problem
By Driftking978 in forum Capturing and VCRReplies: 5Last Post: 28th Apr 2008, 17:44 -
Capture problem
By jjaha in forum Capturing and VCRReplies: 0Last Post: 9th Mar 2008, 15:08
