Ok I have a movie that I download off the net that is an avi file. I downloaded nimo and divx bundle to try and play the movie but it just wont play on my windows player or divx player... How do I convert it to divx so I can play the movie?
It could be a fake
It won't play
Open the file in virtualdub, select file, file information. What information does it give. -
VIDEO STREAM
Frame size=352x288,3000
# of frames=9694 (53:51)
decomposer= Uncompressed RGB1
Number of key frames=9694
min/avg/max/total key frame size=12672/12672/12672(119964k)
min/avg/max/total delta frame size=(no delta frames)
AUDIO STERAM
This is what it says word for word! -
Well it is not a divx, it uncompressed RGB. When you try to play it does it give an error, or does it actually play but you just get a black screen. It seems to me that it is a fake file. It should play because there is no compression codec used. But it is probrably just a capture of a blank screen.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 05:19 -
divx to avi with divx author
By pred in forum Video ConversionReplies: 4Last Post: 12th Nov 2008, 22:32 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 12:28 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 10:26
