  1. can any1 help ive downloaded the new dvd2svcd ,the problem is it wont convert any audio ,besweet is in the right place,i have just recently installed win2000 i was wondering if any1 ealse has this problem using win2000.and also is there an alternative for doing the audio with dvd2svcd.thanks....
  2. I'm still using version 1.0.9 build 3 with no problems at all on Win2k with service pack 2.
    About the only thing that I can suggest would be to download the program again, maybe from a different site, or maybe download the version that I use. I don't plan to upgrade my version, as it seems to work nicely with no problems.
    I just noticed that you said you recently installed Win2k. Did you install all the necessary codecs? That might be your problem.
  3. still no joy,i have all the same stuff on my computer when i had win milleniun,what codecs ,i have nimo codec pack and divx3.11alpha,strange windows millenium didnt give me this shit......
