  1. I really need to know how I can burn .bin files! My burner isnt supported by much... its a HP cd writer 9100i CD-R Win and Nero are the ONLY progs I know that are compatible. Is there any way at all to burn .bin files to a cd??? I tried but I've wasted over 15 cds already! PLEASE if you can help me e-mail me at wdudeboard@hotmail.com or ICQ me 106197963 THANKS!
  2. Member adam's Avatar
    Sep 2000
    I'm assuming you have only the bin file right? Well your supposed to have a cue file too. If you don't then just use CDMage to generate a new one. Its in the tools section, its pretty self explanatory and it will just do it for you.
    Then you can load the cue file into cdrwin or nero (file/write cd from image.)
    Even without a cue file you can still load the bin in nero you will just have to tell it the correct settings, which depend on what your burning. Data cds are mode 1, vcds and svcds are mode 2 etc.
    Actually the HP 9100i should be supported by almost all burning programs, you might just have to download some new drivers or update your burning software.
