Hi there,
after I encoded a Movie from a VOB (from OSEX) into a mpeg-2 movie by using MMT (SVCD-PAL), .. encoding the audio to 224kbit mp2 soundfile, I used the mpex option to multiplex the movie into 3 chunks (790MB).
Everything worked fine, also generating the svcd-xml-script by using the vcdxgen option, ..... but when i choose vcdxbuild to generate the cdrdao images i got an error while generating the image for the second chunk.
Can you help me!?!??!?!?
Here is what the terminal says:
-------------------------------- Terminal output ----------------------
Welcome to Darwin!
cd /Applications/MissingMpegTools.app//Contents/Resources
./vcdxbuild --cdrdao-file=/Volumes/Hauptserver/Agentur/Kreation/Diverses/video/untitled\ folder/UNDEFINED//MyGreatMovie /Volumes/Hauptserver/Agentur/Kreation/Diverses/video/untitled\ folder/UNDEFINED/UNDEFINED/hqvcd.xml
[localhost:~] xxxxx% cd /Applications/MissingMpegTools.app//Contents/Resources
[localhost:MissingMpegTools.app/Contents/Resources] andrej% ./vcdxbuild --cdrdao-file=/Volumes/Hauptserver/Agentur/Kreation/Diverses/video/untitled\ folder/UNDEFINED//MyGreatMovie /Volumes/Hauptserver/Agentur/Kreation/Diverses/video/untitled\ folder/UNDEFINED/UNDEFINED/hqvcd.xml
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
++ WARN: this is the UNSTABLE development branch!
++ WARN: use only if you know what you are doing
++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
++ WARN: mpeg stream contained no scan information (user) data
INFO: scanning mpeg sequence item #0 for scanpoints...
++ WARN: sequence items should contain a motion video stream!
++ WARN: generated image (357270 sectors [79:23.45]) may not fit on 74min CDRs (333000 sectors)
++ WARN: SVCD/TRACKS.SVCD: No MPEG motion video for track #0?
!ASSERT: file vcd_data_structures.c: line 217 (_vcd_list_begin): assertion failed: (list != NULL)
Abort
My guess, you used force segment in mplex. When ever possible set the segment flag in the mpeg2enc, then mplex will correctly split automaticly.
Anyway, the error in vcdxbuild thinks it's an mpeg still in a sequence that only allows mpeg motion. The part 2 and 3 splits must be missing some header info. Try demuxing then remuxing. Or mux the original as a single mpg, then split with mpgtx or JAW.
Let us know what works.
RNC
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 13:08 -
.avi files that won't work correctly!
By RolloSwe in forum MacReplies: 10Last Post: 24th Feb 2011, 10:45 -
By RolloSwe in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 16:41 -
Won't create .img disk image
By LoafingOaf in forum ffmpegX general discussionReplies: 1Last Post: 13th Feb 2008, 10:02 -
DVD's no longer playing correctly on PC, image very dark
By tpham000 in forum ComputerReplies: 0Last Post: 4th Jan 2008, 09:50
