After reading all of the great info on this site I decided to dive in and try my hand at making my own video projects (vcd and svcd for now).
Yesterday, I ordered the Canopus ADVC-1394 and recently I built my own rig. Here are the specs. Let me know if you think it is sufficient or if I should add anything. Thanks!!!
WinXP - AMD 1600XP oc'd to 1.6ghz - 2x80g WD Special Edition hd's - 256mb DDR ram- onboard AC97 sound - Liteon 40x cd burner - Visiontek GTS-V 32mb DDR video card
for the future- sony dru500 dvd burner.
Welcome Aboard
This place rocks! 8)
and yes your system should be able to handle it. its better than mine but i havent got into capturing yet , just ripping ,converting & authoring. -
Andysly5,
Sounds like a great system, you said...
Let me know if you think it is sufficient or if I should add anything.Evil flourishes when good men do nothing. -
Thanks for the suggestion!!!
Upping the ram is definately the plan but with blowing $240 on the ADVC-1394 yesterday, it will have to wait. The soundcard, however, may be a bit more feasable. I think Newegg has it for approximately $35.
