I can't find the pulldown for resizing to CVD... ?????
I have the same problem with DVD2SVCD. The guide here at http://www.vcdhelp.com/forum/userguides/98376.php states to get V1.0.9 build 3 from the Doom 9 forum. The Doom 9 forum now points to a place to get V1.1.0 build 1. The frameserver tab no longer has the Resize to pulldown menu as the guide shows instead it has a Parameters Value, and again, no CVD option.
I was able to find/download V1.0.9 build 3 from www.dvd2svcd.org. When I installed it the same thing happened. Any ideas? I really would prefer to use CVD format.
There is another similar guide at: http://www.afterdawn.com/articles/archive/dvd2svcd_guide.cfm, and in the "SVCD or CVD?" section it shows you can easily create CVD's with DVD2SVCD. It states "Go to the Frameserver -tab and use the Resize to -pulldown menu to choose a format of your liking."
I tried both versions on two different systems (a Windows XP Pro (SP1) system and also a Windows 2000 Pro (SP3) system) and I still do not have the field shown in the guides.
Since the VCDHelp guide mentions the Doom 9 forum I really wanted to post this there but they will not allow you to post until at least 5 days after you register, and I just registered. -
Its there,
just that you need to read the instructions before asking
FIRST GO TO THE MISC TAB AND SELECT DVD2SVCD LEVEL: ADVANCED.
the very first instruction on the guide, with out it being set to advanced the CVD option is not available.
Take care and remember double check always
ciao
TLTwThe Hellsing family will purify this world...
Folders changed into 32 kb files, help!!
By caesarhawy in forum ComputerReplies: 1Last Post: 27th Apr 2011, 13:57 -
Things have changed
By Marco33 in forum Off topicReplies: 13Last Post: 23rd Dec 2010, 21:29 -
After burning, the DVD changed to CD
By coody in forum DVD RippingReplies: 2Last Post: 29th Sep 2009, 12:41 -
WMP changed
By KLouis22 in forum Software PlayingReplies: 5Last Post: 5th Dec 2008, 07:36 -
Using Super - can paths be changed?
By Will_Annand in forum Video ConversionReplies: 3Last Post: 4th Jun 2008, 13:24
