Results 1 to 12 of 12
  1. I was trying to create a SVCD with this kind of menus. That was a session of my band playing at my house garage and the menu would be like this:
    Begin Movie
    Interview
    Music Selection:
    This link "music selection" would so take to the other menu with the music list.
    Sure this is possible in DVD, but when i tryed to make a SVCD with this kind of menu with Pinnacle Studio 8, the software crashed during the "disk compilation" fase. I was observing and verified that the crash happens just when was compiling the link that take to the other menu.
    So i suspect i can't do links between two menus, just between a menu and a movie scene...
    Any help?
    Thank you guys!
  2. Yes, very easy to do with the right software. Look at the freeware VCDeasy program (GUI for vcdimager) at http://www.vcdeasy.org/ This will allow nested menus and more.
    Panasonic DMR-ES45VS, keep those discs a burnin'
  3. VCDEasy can work with SVCD too?
  4. Member adam's Avatar
    Sep 2000
    Yes.
  5. man... i was trying with this VCDEasy and i just canīt see what i'm doing... just a kind of code that seams like HTML or something... i want something more newbie friendly! LoL!
  6. I use TSCV myself. It is another front end to vcdxbuild, and builds the xml code in the background. Setting menu jump points isn't the most intuitive, but I figured it out after a few attempts.
    I thought that the menu controls in I-Author were pretty good, but that is/was a commercial program, and made non-standard folder names, which some DVD players might not like.
  7. What about Ulead DVD MovieFactory?
  8. im using "dvd workshop"
    its grate, very eazy to understand.
    you can make whatever menu you like.
    HELL AINT A BAD PLACE TO BE
  9. What do you want - crashes in Pinnacle or take a few minutes to learn a more powerful program?
    Yes VCDeasy makes a XML file to feed to vcdimager but you don't need tgo worry about it - go to the screen where you add menus and clips - very easy. It will make a bin/cue file set which can be burned a number of ways (see Author section on this site).
  10. I'm trying this Ulead stuff and it looks good. I'll learn about XML someday!
  11. Man... i'm using DVD Workshop and its great! Thanks for the tip. Thanks for the VCDEasy tip too, but i don't have the time to learn XML now, maybe latter!
    USA
    Hi all, I just have a quick question on VCDEasy.
    If I capture a few music videos with my TV wonder and then try to create a VCD with a menu that I can select to play which ever song I want to using the dvd remote....is this possible. The menu would be like a DVD menu.
