I'm just starting to use virtualDub to capture my old Home movies from VHS and I just about got everything figured out but the sound. I read the guides and did everything it says but I can not get any audio to capture. When it's capturing I hear the audio but if I turn on the audio meter it show's no audio being captured. If anyone has a suggestion I would very much appreciate it.
Thank's
Make sure your TV card line-out is going to your sound card line-in (sounds like it is if you can hear the audio). Also double click the speaker icon in the bottom right-hand system tray on the screen - options-properties - recording. Make sure the "line in" is ticked. Click OK then make sure line-in is ticked (default is "mic" ). Hope that helps
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 23:17 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 20:19 -
Bitrates, capturing with VirtualDub
By epicap in forum Capturing and VCRReplies: 4Last Post: 3rd Sep 2009, 10:49 -
Capturing using Virtualdub with Vista
By qwerty99 in forum Capturing and VCRReplies: 17Last Post: 27th Feb 2009, 20:59 -
What level should I set the audio to when capturing analog in VirtualDub
By drinklime in forum AudioReplies: 3Last Post: 20th Jan 2008, 08:45
