  1. I just encoded aavi to MPEG using TMPGEn then I split the MPEG using the TMPGEN MPEG tools merge and cut.
    I burnt it using Nero set on VCD and it burnt ok.
    I play it on my DVD and the picture is superb but there is no sound.
    I previewed it after downl;oading this avi and there was sound.
    Can you help me?
  2. Before you encode with TMPGE, extract the audio using Virtualdub and save as a WAV using this:
    http://www.vcdhelp.com/virtualdubaudio.htm
    "Today is only yesterdays tomorrow"
  3. oh...and i suggest rather than wasting any more Cd-r's ...try a short clip on a CDRW first.
    PA, USA
    Originally Posted by pete3003uk
    I previewed it after downloading this avi and there was sound.
    Can you help me?
    after you cut encoded and cut the MPEG, did you preview that to make sure there was audio?
  5. Originally Posted by johneboy
    Can you help me?
    no but i kept the mpeg and i find that sound has gone so TMPGEn lost the sound
