What is ac3?
LAMA section here we go)
I have a movie that has 5 channel sound according to vdub file info.
is that it?
Anyway vdub doesnt save the waw for me, what next? ( I'm converting from ntsc to pal so I need to separate the sound )
ac3 is an audio compression used on dvds, and some vcd/svcd variations.
go to this site to learn about ac-3
www.dolby.com/company/is.ot.0011.TechOverview.03.html#s3c
if you want to keep the sound as it is - just tell virtualdub to make
a direct strem copy and save it as whatever name you want.
if you are looking to convert it to wav, then you will need a program called
"haeadac-3ch".
but befor you use "haeadac-3ch". you need another progam to check if
the ac-3 file doesnt have errors in it, the program you will need is
"ac-3 fix"
if you need something else - post a reply.HELL AINT A BAD PLACE TO BE -
thanks all!
everything works fine
the project is in cce-s hand now....... ( and I'm waiting patiently)
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 20:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
