I have just upgraded my system and am now having trohuble with capturing in both win98 and xp
I can capture OK in Win98, but as I am capturing to convert to DVD, I need 48000khz audio. When I select audio compression, it only goes up to 44100khz. Now my soundcard supports thsi, as I've had it working before (Soundblaster 128 PCI), but whatever I do (installing the drivers, disabling stuff), I still can't get the option to choose 48000.
Anyway, in Windows XP.....
I have been using this for ages to capture, using a patch files in the Matrox folder, but now I've got a new system and I've reformatted I can't get it to work properly. I CAN selct audio 48000, but sometimes it captures fine, the capture again and NO FRAMES are captured. This happens with AVI-IO.
I know this should work, as I used it with my old system for months. Could it be my new board and chip?
Anyone else got these problem
Results 1 to 1 of 1
Matrox MX02 Mini or Matrox MX02 Mini Max
By Cingular in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2009, 20:27 -
Capturing problems
By dbrunton in forum Capturing and VCRReplies: 9Last Post: 27th May 2009, 13:09 -
Need help in choosing a video capturing card - Matrox
By avinash.rao in forum Capturing and VCRReplies: 0Last Post: 1st Aug 2008, 07:49 -
Is the Matrox RT.X2 worth it?
By shockaholic in forum EditingReplies: 1Last Post: 22nd Jul 2007, 14:31 -
Having problems capturing from VCR
By Confused Chimp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2007, 02:41
