Hello
Im using CCE for encoding, so I separate AVI and WAV first. Then I do AVI to MPEG encoding with CCE (with FitCD Help, avs-File) and encode the WAV to mp2/3 with HeadAC3he. So Then I got a Video File and Audio File which I have to join. I wanted to do this in TMPGEnc - MPEG Tools, but every Time I try to multiplex/simple multiplex, he says at the end: xxxx packets caused buffer underflow. Of course I can watch the movie and it looks great, but I cant burn it with nero, becoz he says the Bitrate aint VCD compatible... But I did choose the right (1.150) Bitrate in CCE (CBR of course). Now Im not sure but I think that TMPGEnc is responsible for this, becoz of this pockets which cause buffer underflow.
Has any1 experience in this?
thanks
You can normally override Nero compliance checking provided your Player can play non-standard VCDs called XVCDs.
A couple of things to check:
Are you using CCE in VBR multipass or are you using CBR at 1150 bits ? If you are using multipass VBR then it may be that your peak bitrate is too high for VCD spec so that is why Nero is saying it is non-compliant.
Check your audio bitrate as I belive standard VCD requires audio bitrate of 224, no higher no less.
Also mux with mpeg1 system rather than VCD as this should stop the buffer underflows if your bitrate etc is VCD non-compliant. -
Yea, my my DVD player cant really play it, the video is not fluent.You can normally override Nero compliance checking provided your Player can play non-standard VCDs called XVCDs.
Im using CBR @ 1150Are you using CCE in VBR multipass or are you using CBR at 1150 bits ? If you are using multipass VBR then it may be that your peak bitrate is too high for VCD spec so that is why Nero is saying it is non-compliant.
I have CBR, min 224 setup in HeadAC3heCheck your audio bitrate as I belive standard VCD requires audio bitrate of 224, no higher no less.
Yea I tried this, but its the same... he even gives me the same amount of packets.Also mux with mpeg1 system rather than VCD as this should stop the buffer underflows if your bitrate etc is VCD non-compliant.
Is there another Tool to mux video and audio to mpg? Or another Idea, Im really perplexed. -
BBMPG is very good. I usually use this over TMPG for muxing. You should find a link to download it in the tools section on this site.
hmm, I tried bbmpeg but as soon as I click open PS or open VS, it will close immediately without a warning...
MuxMan : Buffer Underflow
By Bonie81 in forum Authoring (DVD)Replies: 3Last Post: 23rd Oct 2011, 15:38 -
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 03:45 -
issues with wmv for xbox encodes (buffer problem)
By DsOft in forum Video ConversionReplies: 0Last Post: 3rd Dec 2008, 11:52 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 10:51 -
Buffer overflow in tmpgenc?
By themaster1 in forum EditingReplies: 7Last Post: 15th Jun 2007, 16:08
