When I tried to take a screen capture of an mpeg video, it came up black/blank. Will HyperSnap only take pics of .avi?
Also what's the best way to convert mpeg back to .avi?
If you disable hardware/video acceleration in your video player, you should be able to take screenshots of any video, even if you just use the Printscreen key.
-Cart
http://www.geocities.com/lukesvideo/index.html -
What does hardware accel. actually do? Does it affect video quality or does it help prevent buffering problems?
It reduces CPU usage and can help improve the quality. For example, most video cards will filter the video to remove blockiness when the video is scaled past 100%.
You should disable acceleration when taking screenshots and enable it when you're finished.
-Cart
By Krissu in forum Newbie / General discussionsReplies: 5Last Post: 16th Apr 2011, 14:45 -
How to take BluRay screen captures - FREE
By SOHkat in forum Software PlayingReplies: 14Last Post: 11th Feb 2011, 16:56 -
AXIL RT 196 TDT tuner+PVR: how to convert captures from .TS to .mpg?
By Paco M. in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 07:16 -
Screen Captures?
By newsphotog in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 16:35 -
Screen Computer Captures
By Steverup in forum Capturing and VCRReplies: 4Last Post: 5th Jul 2007, 23:02
