    Aug 2002
    I recorded some shows onto the HDD of the HS2, and then when I had enough material, I burnt them to a DVD-R. I tried to rip one of the shows for a friend off of the DVD-R, but it didnt work. I used Smart Ripper to rip the .vob files, and I tried TMPEnc to transcode to VCD. It only made it about a minute through the file, and even then, there was no sound. I am prolly just making a dumb mistake seeings how I am new to all this. If anyone could help, it would be great. Thanks...
    --Drew
    Have you just tried to copy the files to the hd(dont use smartripper) and then convert? Cause they should not be encrypted.
    Aug 2002
    No I havent, but I will try that. Thanks for the tip... I will let you know how it comes out...
    --Drew
    Aug 2002
    Well, I am still getting no sound. I load the .vob into TMPEnc, and it doesnt show an audio source... Is there a different way to do this? I mean there has to be something besides TMPEnc that can do this. Sorry if its a dumb question, I am a newb. Thanks Baldrick... any suggestions would be appreciated.
    --Drew
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    use dvd2avi as a frameserver and open in tmpgenc
    http://www.vcdhelp.com/sefy/?id=frameserv1.html
