  1. What is the best/easiest software to edit DV and then convert to DVD?
  2. Moviemaker2 that is free with WindowsXP
    http://download.microsoft.com/download/WinXPHome/Install/2/WXP/EN-US/setup.exe
    It can import the DV file and add special effects.
    Hint: save as DV-NTSC file as it's mpeg encoder
    is not as good as tmpgenc.
    tmpgenc is the program you will use to convert to m2v and mp2/wav
    that you can dvd-author with ifoedit0.95
    If you bought a dvd burner it probably come with Sonic-MyDVD
    and it have more features.
